- Jun 18, 2015
- 712
- Plaster
- Pentair Intellichlor IC-40
Hello everyone -
I’ve tried to research the forum for the latest information/equipment from Pentair, but realized that it might be easier if I just post and ask for your advice and recommendations. Their website is overwhelming, as I just need to know what the best workhorses are! I’m a designer, so the equipment isn’t my thing. At I least I know enough to consult with the very best! Everyone on this forum has been amazing - and has helped us so much with our existing pool here in Atlanta.
My husband and I are renovating an existing pool in St Croix USVI (long distance, isn’t that fun?) and having the equipment shipped from a distributor in Florida. Our existing pool in Atlanta GA was renovated several years ago with new Pentair equipment (listed below) and we’ve been very happy. We definitely want to stay with Pentair because we’ve had such a good experience and want everything to work together.
Any advice/thoughts will be greatly appreciated! I need to send this list to be purchased ASAP.
Please keep in mind that we are in STX only part of the year and while we do rent the house often, we will have a local company checking on and cleaning the pool regularly. My thought is to purchase workhorses that are not overly complicated and easy to use.
Thank you - Amy
Pool: approximately 30,000 gallons. Partially inground gunite with plaster and Ecofinish (we love that finish in case anyone is interested!)
Equipment room: located under the back (ocean side) of the pool and completely hidden from view. All concrete.
Control: Pentair Easytouch Automatic Control (is IntelliCenter a better choice?)
Pump: Pentair IntelliFlo3
Salt System: Pentair Intellichlor 40 (is a Pentair Intellichlor 60 enough for this “new” pool?)
Heater: Pentair Mastertemp (we have 400,000 BTU for our Atlanta lap pool, but STX will need an electric/heat pump or propane. Asking locally to see what is recommended). Would the UltraTemp be a good option? Our pool is above sea level and gets a constant breeze, so it’s crazy how often the water is cold. We have solar panels on our house, but it’s been recommended to get separate ones that water run through for the pool. Then why would we need a separate heater? This is so confusing, so would appreciate any advice on what really works. The pool is in full sun. Again, you’d think it wouldn’t require heating!
Filter: Have had a cartridge filter recommended to us. Pentair has a few. Any idea which is best to purchase?
Light: Pentair IntelliBrite LED (unfortunately we can only install one to work in the existing cavity. Wish someone would invent a way to add lighting without having to bore into an existing structure)
Thank you - Amy
