Hi All,
I had to replace my pool light this past summer (long story), but the electrical wire was epoxied in place in the niche. So, I had to take a chisel and bust up the epoxy to free the wire. Well, that epoxy must have been sealing a niche defect, because the water left steadily dropped for weeks and is now resting at the light height. I'm guessing there is a hole in the niche or in the conduit that attaches to the niche. I'm planning on getting a submersible pump an pumping out the water to a storm drain, then looking for the hole.
Has anybody had any experience with repairing/replacing a niche or PVC conduit that attaches to the niche? If so, any advice would be greatly appreciated.
Also, I figured I might as well re-plaster the pool, because there are some nasty stains. Anybody have any experience with that? I know I have to do a muriatic acid wash, but what type of plaster should I use? And what if the existing plaster sort of crumbles when you scrape it with your hand? I don't want to pay anybody to do any manual labor I can do myself. I'm a noob when it comes to pools. I can maintain the chemical balance, but I want it to look a lot nicer this summer for my wife and daughter, and I don't want to spend a fortune. I don't know what type of plaster currently exists; I'mView attachment 56634 hoping one of you wise folks will be able to tell from the picture and say "yeah, all you need to do is empty the pool, clean it with x chemical, re-coat it with y plaster, and seal it with z product" or something like that.
Cheers!
Cheers!
