cfherrman
Measured TA. Use Pool Math and it will figure everything else behind the scenes.Just so I'm clear - TFP recommendations refer to measured TA?
E.g. for my pool it recommends TA 60-80
So that's the raw reading, which will include a certain proportion of CYA alkalinity?
If so, then TFP is recommending TA levels about 50% of the recommendation of an Adjusted TA of 80-120?
Because the higher the TA the faster pH rises. As has been pointed out above, you can never stop pH rise, only slow it down.Can I please get a layman's explanation as to why I should not believe that increasing my TA ppm just like you do the chlorine ppm to compensate for the excess CYA I would be a logical adjustment ?
Because CYA and TA are the hardest two things to adjust. Raising TA is easy, just toss in some baking soda. But, as I said above the higher the TA the faster pH rises. Lowering TA requires a system of lowering both pH & TA with acid and then just raising the pH back up whit aeration, repeat as necessary. CYA can only be lowered with water exchange or an RO treatment.why can't you just adjust your TA or CYA level to accomplish the same thing if it will help with the PH
The feed back has been great and I appreciate it very much. I am coming to understand the CSI and calculator as a whole much better than I did initially. But I still have some questions. First I do realize there is initial rise in PH after adding chlorine to the pool water. I test in the morning to only find out how much chlorine was added via my feeder & pump running overnight and if it's sufficient. Second I test for TA and PH at the end of the day when I will get a truer test result along with the chlorine again so I can determine how much chlorine is being depleted to gage if my FC level is at least at the min. level when swimming is most likely so I can adjust the feeder.
OK so what I'm understanding is that the pool math does factor into it's CSI calculations CYA adjustments to TA when the "Now" stated for CYA is over 30ppm to obtain the "Carbonate Total Alkalinity" automatically. That's good to know, although it is not stated so in the description of the CSI calculations on Pool Math. The point I am having a hard time with is why if CSI results, which is apparently what most people are concerned with as representative of being "Balanced", the "Adjusted TA" part is being portrayed as non important then. Additionally I can't get my head around why if the CSI factors in the calculations for the True Total Alkalinity based on CYA to make adjustments to balance your pool water why can't you just adjust your TA or CYA level to accomplish the same thing if it will help with the PH and lessening the addition of acid upfront. These concepts are hard to follow. I just have a hard time with the idea that I am glued to the pool with acid and I can't improve my maintenance level even in Arizona where there are more pools per capita than most other states. I have come to the realization that the high Calcium (hard water) presently over 600ppm and high CYA levels I have are major factors in my problems because that contributes to the "Carbonate" which effect alkalinity that effects PH. The Taylor manual CSI calculator, Watergram" that comes with the 2006C test kit does require you to adjust the TA by CYA by 1/3 to find the correct CSI values. The bottom line is this value is subjective to what all the other tests results are stated allowing you to adjust each of the individual levels in order to reach a CSI in a good range so you know where and how much you want to make adjustments with acid etc to reach that goal/CSI value.
Can I please get a layman's (for dummies) explanation as to why I should not believe that increasing my TA ppm just like you do the chlorine ppm to compensate for the excess CYA would not be a logical adjustment as I am already getting encouragement to do?
I'll google it up, thanks.
Additionally, I would like to mention on Page 14 of Taylor Water Chemistry guide booklet (part #2004B) provided with the Taylor water test kit 2006C includes a paragraph titled "Cyanuric Acid Correction to Total Alkalinity". The formula stated is Alkc = Alkta - (measured CYA x 0.33). Which simply states TA measures all forms of alkalinity (aka Total Aklinity) including Carbonate Alkalinity and Cyanurate Alkalinity present in the water sample. Since "water balance" calculations (Saturated Index I believe they mean) ONLY USE THE CARBONATE ALKALINITY PORTION, a correction (which varies with PH) should be applied to compensate for the CYA alkalinity portion. For most waters "within" the recommended ph and CYA acid levels, using this factor is only within experimental error (not needed I assume they mean).
This final Note is what I found most helpful to me in understanding the confusion I'm experiencing; "While Taylor Technologies recommends using the correction, some members of the pool/spa industry question it's value" and I can validate that is a true and correct statement. I'm just the type that keeps an open mind and absorbs all information as valuable for the best possible outcome and right now that's controlling and or balancing my water taking in all various factors I have learned here and from others who have offered their time and knowledge to help me learn how to care for my pool myself at the prime age of 65....never say your too old to learn!
Because the higher the TA the faster pH rises...
I get somewhat confused when I try to understand your explanations and I certainly don't want to cause you any irritation but I probably am, sorry, but in the beginning you say Pool Math does this correction behind the scenes automatically, but in the next statement you staunchly dismiss the need for the correction and that it's just some old junk science from a different time period and water application. I just don't understand all the other various scientific pool water analysis; such as another one I just found on the subject at http://www.aquaticspecialtyservices.com/msds/techbulletin2.pdf which is nothing but about testing pool/spa water and the accuracy of SI calculations which is the true indicator your water is "Balanced" to avoid damage to your pool which is a critical aspect of pool water maintenance. Water is water and this correction being discussed is specifically addresses high levels of CYA in stabilized pools due to usage of Chorline Tablets in CYA build up over time and once it reaches a high concentration in combination with a certain PH level, it produces a TA test result that in fact has changed composition, therefore not truly accurate when it is used to determine the SI level and will produce a false SI "balanced" result. This basically says, if you have very high levels of CYA in your pool water when your ph is 7.2-7.8, a chemical change occurs where the CA, "cyanurate acid", replaces the carbonate in Alkalinity and increasing levels of CA as much as 73% to 83% of the TA test result depending on the PH levels. This is then being used to calculate the SI as a carbonate unless the TA is adjusted as recommended or the alternative would be to drain and or remove (osmosis) the excess CYA down to the recommended level for any pool sanitizing method. I have to admit the information is very compelling.
So going back to my original post regarding my PH stability issues, is this very same scenario of lower levels of carbonates conversly affecting my PH buffering thereby lending to a PH bounce up effect or is the CYA a PH buffer too and not applicable in this scenario or should I then increase my TA level based on the previous informtion with Bicarbonate to compensate as recommended too? Would this do double duty and negate the need to make the TA calculation adjustment for the purpose of the SI results? Well, I don't want to annoy anyone here over this subject but you just have to scratch your head!!!! I also realize this might be unsettling to the Tri-chlor/Di-chlor industry if all this were actually true.
So why the traditional recommendation for a higher TA (around double TFP's recommendations), given that carbonate->CO2->outgassing is the primary driver of pH rise?
We seem to be drifting away from DrD’s desire to stabilize their pH and reduce acid use again.It seems like there’s a handful of discussions here. Let’s try to focus on DrD’s desire to stabilize their pH and reduce acid use.
So did the pool industry copy TA recommendations (80-120) from other industries, and it became gospel over time, similar to FC of 1-1.5 being "ideal"?
