- Aug 12, 2022
- 107
- Vinyl
- CircuPool RJ-45 Plus
Is there such a thing as an adjustable flow return outlet? When I built my pool, I have 4 return jets, and I made the mistake of running the water supply to the slide off of the closest return line thinking there'd be enough pressure to supply the slide. With all 4 returns open, there's not enough pressure to push water up the slide supply. If I block off two of the returns, there is enough water pressure to the slide. An adjustable flow outlet would be convenient so I don't have to remove the return eye and plug the return. Any thoughts?
