After talking to the electrician I was expecting to be able to run a white (neutral) from the outlet in the first pic to use for my smart switch. You can see in the photo where I fished a new wire through. When I wired it all up, the smart switch didn't work. I have the black wire from the original toggle switch connected to line and the blue wire to load on the smart switch. In the bottom pic with the smart switch, you can see that the white now goes in and goes out of the neutral terminal - it was initially passing through the box when the toggle switch was there. The white then connects to to the of the outlet in box below.
My thinking was this:
White = Neutral
Black = Line
Blue = Load
But I now suspect that I'm missing something. Any suggestions?
Thanks in advance!
-Pat
White = Neutral
Black = Line
Blue = Load
Thanks in advance!
-Pat
