How was the IntelliConnect bypassed?
Do you have a water temperature sensor installed?
If the IntelliConnect will control a gas heater or heat pump, a water temperature sensor, which is sold separately, must be installed between the filter pump and filter.
Also, your pump needs to be under control of the IntelliConnect and the Pentair POOL App.
Will this turn on the heater? This tests if the heater is installed properly and bypasses the app - While IntelliConnect is in SERVICE Mode, simultaneously pressing and holding the RELAY1 and RELAY2 buttons for 3 seconds will activate the heater. The Demand Response LED will illuminate amber.
www.troublefreepool.com
