I read in many threads here that I should be adding MA very slowly, without diluting it and by where the Jets are so they would help the acid circulate and mix quickly. Being new to this I need a clarification. My Jets are at the bottom, popping up and down, changing every some 30 seconds or so. The only wall/side jet is right under the return/skimmer. So still ok to dump there? I don’t want acid to be immediately sucked into the skimmer. What’s the best course of action for someone in my case?
thank you!
thank you!
