So this year I have experimented with adding DE to my sand filter. I did this first time clear out some finer debris after I finished a SLAM, but wanted to maintain this as a routine after each backwash.
After a fresh backwash, my pressure gauge is reading exactly at 12 psi. I usually need to add 2.5-3 cups of DE powder to get my pressure up to 13. However after a couple on and off cycles on my pool pump, the pressure never recovers back to 13, but drops back to 12 (or a bit above). My guess is that after the pump cycles and filter loses pressure, the DE has a chance to resettle a bit causing less pressure next time the pump is turned back on.
So my question is, should I add more DE after this happens? Or just assume that the DE I added is still doing it's job.
