Has anyone added an inner layer of plywood to an above ground pool's walls?
Thanks
Joe Papworth
Delaware, Ohio
Thanks
Joe Papworth
Delaware, Ohio
Yes. It's a Sun Holiday pool. TFP says the photo file is too bigAre you saying this pool was already built with plywood?
Got any pics?
Take screenshots and edit out the unnecessary parts. Then post the screenshots.TFP says the photo file is too big
Instantly it looks like a semi inground, and nothing like I was expecting with your 1st post.Someone requested pix but these don't tell you much because the work is done and the pool has been refilled.
I specifically asked if anyone had experience with adding a second layer of plywood wall to an above ground pool.Well the framing would sure be nice to see. But with so very little to go on, it's impossible to help you.
So far, we have 'is a one of a kind repair to a nearly one of a kind pool ok ?'
I for one, would be too busy playing lotto if I was psychic.![]()
