Added too much Calcium to skimmer - how to get rid?
May 14, 2018
1
East Hampton
So I added Calcium through the skimmer (only now see that I should have pre-dissolved), and a bit too much. I noticed it clogged in the pump filter basket so I cleaned that up, but there must still be a decent amount in the lines. When I run the pool now on filter and recirculate, the jets shoot out cloudy water, and often bubbles or a slight foam appreas in the deeper end. All chemical levels seem okay, within range. I'm assuming the Calcium flakes are in the lines and slowly dissolving and coming out the jets. Plus, the skimmer's suction seems a little weak as debris tends to gather around the deep (skimmer) end. What is the best way to remedy this - removing possible Calcium flakes sitting in the suction lines?? Is there something I can add to the suction lines where the extra calcium must be sitting to dissolve it? Any info would be greatly appreciated.
