Added Calcium Chloride and Soda Ash
Cards12783
11
Memphis TN
Like an idiot I added Calcium Chloride and Soda Ash right after each other not realizing I wasn’t supposed to and now the water is super cloudy and Milky. How long will it take to clear? Should I just wait or should I do something to fix it? CH was low and PH was low so I added basically at same time. Please Help!
Post a full set of water chemistry test results. Low pH typically needs no action unless your TA is also very low.
The cloudy will clear once the chemistry is stable.
Thanks for your reply:
Cleared some overnight. Big mistake with the soda ash but obviously created a chemical reaction mixing those chemicals and created calcium carbonate.
Test Results this morning are
PH 7.4
ALK 105
CH 220
CL 4.2
CYA 35
Slightly negative CSI at the moment
