- May 27, 2019
- 1,624
- Plaster
- Hayward Aqua Rite Pro (T-15)
I added the Boric acid and see the other thread about using the Crud from Home Depot.
My TA did not change based on the TA test, still about 70. I'm also increasing my CYA to 80, about 1/2 way there (76 with my eyes). The goal for me is to reduce my CA down to a level that the maximum pH is 7.9-8.0.
If my reading really is 70, then, the Carbonate Alkalinity should be TA - (CYA/3) and (Borates/8). This means a CA of about 38. Using this chart, being between 30 and 40 Carbonate Alkalinity, I should have a ceiling of just under 8.0. Which should be a very respectful pool pH these days. Even with an 8.0 pH, the CSI is a negative -0.12 (85F, 50 ppm Borates, 80 CYA, TA 70, Salt 3000, CH 350).
Should I bother trying to drop the TA to 60? It looks like leaving it 70 is better.
