Our pool pump is on a timer. We have had a few instances where the pump has failed to prime at start up. I'm pretty sure the failures occurred after we have cleaned out the pump basket, so we are being extra careful now to clean it out, fill with water and start the pump afterwards to make sure we don't have any leaks.
When the prime failure has occurred in the past, we have observed what I believe is DE in the basket and I believe a bit is circulated in the pool as well after we get the pump primed and going again. Hopefully we have a good handle on the reason the prime failure occurred so it will not happen again. However, if it does, do we need to add more DE back to the filter? Backwash it? Just hoping to understand what we should do if it were to ever occur again.
