At closing last year, cover ripped and we just left it so I knew opening was going to be a challenge. Went to open last weekend & pump was shot, so had to order a new one. It came in, so we’re hoping to get opened today. Cya test is showing less than 20. We could still see the dot with the tube full, my suspicion is that cya is zero. Chlorine of course is zero. Do I need to add cya before starting slam? My understanding is that the lower cya is, the less chlorine you need to reach slam. Also ph is over 8.4, is it muriatic acid that lowers ph?
