I had a thought today... Does anyone ever put actuators on their valve between their skimmer and suction cleaner, so that they can have their automation system go into a daily "cleaning mode" for a couple hours a day (25% suction to skimmer & 75% suction to cleaner) and then switch over to full skimmer? (Is this even possible w/Easy Touch?) I have an extra actuator on our system for our bubblers that ended up not being needed. The only concern I would have is, if the pool cleaner were ever removed, you'd have blocked water flow to the pump and could possibly burn out the pump if it was only getting 1/4 water flow. Thanks
