I'd like to know some actual dimensions of an EasySet 12'x30" pool when filled up. Does anyone have one they can measure? Specifically:
* Diameter at the base.
* Diameter from outer edge to outer edge of the inflated ring.
* Distance from the outer edge of the top of the inflated ring to the ground, measured roughly along the outside liner wall (not just "straight down" which would pass through the liner and water due to the bulb-shape of the pool).
Thanks!
Thanks!
