Hi All,
Prior to adding 50ppm of borates to my pool (I used boric acid from Duda Diesel), I had very high pH. This was probably due to my SWG and spillover spa. However, the acid demand was always quite low. Sometimes a single drop would take that sample (K-2006) from a fairly dark red back to orange.
After adding the borates, it seems that sometimes it takes 2 or 3 drops to do what 1 would previously do. Is this normal? Does this mean that while the borates do indeed stabilize the pH bounce, it will take more acid to drop the pH when I do add it?
I was adding about 1-2 cups/week before. I haven't really figured out how much I'll need now. I used to rely on the acid demand test a good bit because I have such a hard time telling the difference between 7.8 and 8.0 on the scale. Basically I would toss in a cup or so of acid when it took 2 drops to get back down in the 7.4-7.6 range. I feel like I'm flying a bit blind now.
Shmuby
Shmuby
