You guys are measuring with micrometers and cutting with chainsaws.
Do you measure, down to the last gallon, exactly how many gallons are in your pool, and use that in your calculation? Or do you estimate to the nearest 100 or even 1,000 gallons? Do you take rain and evaporation into account? Sunlight? Temperature? Alignment of the planets? Whether or not Mars in in retrograde? Maybe we should take the curvature of the earth into account, and whether or not there's a low-pressure system coming through today.
Do you measure the volume and concentration of every bottle of bleach you put in the pool? Or do you trust that they're exactly 128oz and 10% (or whatever you use)? If not, this entire line of thought is silly because your super accurate/precise requirements for FC measurement get tossed out the window as soon as you dump in a bottle that you thought was 10% and was actually 7%, or maybe 16%.
This is exactly why there are ranges to the "target" FC levels. This isn't rocket science so there has to be a fudge factor. As long as you're above the minimum FC level and below the shock level, you're good. The target levels are certainly something to strive for, but they're also a compromise between a number of factors. High enough to keep the pool clean, low enough to keep from irritating your skin and mucus membranes, and enough of a 'reserve' so that if you miss a dose it won't result in an algae bloom overnight.
Now I return you to your arguments over 1mL of water.
Welcome to the metric system, where 1mL of water has a mass of 1 gram and a volume of 1 cubic centimeter, and requires 1 calorie of energy to raise it's temperature by 1-degree C.I found that if you buy a cheap digital scale, 1 mL weighs 1 gram. Weigh your samples and never look at the marks on the vials again.
