Just bought a property with a pool that was probably built in the 80’s. I didn’t realise that i placed the end of the vacuum hose to the main drain port (which i had to unplug) as it was the only one exposed when you open skimmer lid. Later did i notice after removing the skimmer basket i saw another port that was not plugged. That’s when i realized that the hose should actually be attached there instead. I’m panicking a bit since i don’t know what damaged i’ve caused. Do you guys have an idea what can potentially happen? Thanks
