This is the first year our pool is a swamp. We stopped covering it several years ago and never had a problem, but fall was very warm, very late in the season and the Cl I'd add along the way wasn't enough. The H2O level is lower due to pool is still closed, but will have to add quite a bit to get it up to where I can effectively run the filter, vacuum to waste etc. But first, we have quite a bit of debris on bottom I'd need to get out (never had the best luck with leaf nets for some reason and can never get them all out). I also worry the amt of chem I'd be dumping on our lawn each time I vacuumed to waste. So my question is, knowing we already have to add water before we can start the filter, then the $$ of all the chems to SLAM, has anyone just drained the pool and cleared out everything, cleaned sides of pool, then just refill instead of the long process of SLAMing? We could probably fill the pool for $200.
