I have some areas in my pool that have some metal staining. I am also going to do a full drain soon due to very high calcium in the water (I have never drained in the 5 years I have had the pool). My question is, can I drain it and dissolve some AA in a spray bottle and spray the areas, then hose them off into the water that is draining? Or would it be best to just dump it in while the pool is still full, circulate the water, and then drain? If I did the later option I assume I don't have to do the sequestrant part of the procedure, correct? I would then just refill the pool....
