A whole year of pool costs (including electrical) :)
Bama Rambler
24,296
Predicated on an earlier topic by Serge I decided to post my costs here.
Since I've closed the pool, these numbers are for the entire year starting at Jan 1 and ending Dec 31. I didn't close last year so i was using chems and electric the whole time. The electric cost will go down next year because I won't be running the pump until I open about April 2011.
Bleach = $167.33
Muriatic Acid = $2.81
Stabilizer = $16.14
Borax = $4.45
Baking Soda = $4.50
Calcium = $1.34
Total = $196.58
That works out to an average of $16.40 per month for chems. I had a couple of uh-oh's with the LQ so next years chems should go down a bit
Our power is 11¢ per KWh and I run the pump 8 hours a day, so that works out to $47.52 per month
for a total of $502.13 for the entire year.
Feel free to post you cost here as well.
i've added my electricity bill increase since pool was completed (allocating all of it to pool ownership, which may not be 100% true)
Pool service (2 months): $ 180
Conditioner: $ 30
Borates : 42
Balance Pak; $32
Cleaner bag + tail foam cover (2): $45
Muriatic Acid: 24 gallons at $5.50 each= $132
Salt: $30
Electricity : +/- $65/month increase after pool x 12 = $780
Total cost ownership/year: $1271
My estimate for the entire year:
Electric $288
Acid $60
CYA $20
Bleach $10 (assist the swg)
Borates $40
Salt $25
Water $30
for a total of $458, $1.25/day
hopefully I don't have to use as many chems next year since cya, borates, and salt are where they need to be. We go through a lot of acid in the 3months of 85+ pool temps. Had to top off the pool a bunch this hot, dray fall. Hope to eventually get a 2-spd motor to drop electric cost. My goal is $1/day.
Above does not include the TPC vacuum, pump repair ($90), some minor tile repair ($30 in 'pool putty'), or the new brush ($25)
Here is my best est
Bleach = $30 (intex swg keeps this cost down)
Muriatic Acid = $30 (Yes, my fill water TA is 300+ :rant: )
Stabilizer = $17
Borax = $20 (Try to keep my borate level around 50ppm)
Baking Soda = $0
Calcium = $0
Salt = $20
Electricity (5mo's @ $65/mo) = $325
Total 5 mo season= approx $450 or less than $100/mo including electric or about $25-30/mo without electrical costs. I guess I could add another $30 for the season in reagents used, if that. :goodjob:
Pre TFP, I used to spend at least $100/mo on pool store recommended chems alone.
