- Jul 17, 2019
- 3,714
- Plaster
- Pentair Intellichlor IC-40
I bet it was from salt and high FC. Have you considered a frog/UV/Ozone system with the optional automatic flocculant dispenser?
So you tried to cheat death. For your TPF followers: How many months/years did you get by scraping and repainting? Was it worth it? Would you do it again, even if you thought you could do it better? Or should you have just pronounced it: "Time of death, 16:22" and just replaced it when you first found that rust? What will you advise others to do if they ask?FLEX SEAL as seen on TV!!!
Okay so we have been working on the dirt and rock movement and chatting while doing so.............why did a pool that I did major research on let go so fast? Well we do live in FloriaDUH so...........humidity is where we are going with this one. Now why those areas? The seams where the bolts/nuts hold the two parts together and along the bottom. I know from the past the whole wall got dewy on a very humid day so why didn't the whole wall rust???
GOT it! So think about this............the seams...........when you put the bolts/nuts on and tighten them you rub/scrape some of the paint/stuff (?)) off!!! Okay so make sure to put something there to cover the metal back up.............now the bottom.........as you are "walking" the wall around to open it up and put it into the bottom rail you are scraping it some on the dirt/sand.................AND some of the dirt might get in the rail so when you push the wall into the rail slot you are again scaping some of the paint off the wall.
Dirk's comment about rust being a cancer got us thinking this way and it make sense. SO any one putting up an above ground pool use care where you might scrap some of the paint off. If/when it happens have the supplies ready (not sure what supplies yet but the stuff Casey posted is in the running for sure) to fix any paint you might scrape off!
Now to see if I can get my hands on some of this stuff to play with and wee if it will do what we need/want it to do!
