My rebuilt ride!
I bought the rebuild kit which comes with everything except for the internal frame and supply hose. I had trouble getting the wheels to spin freely enough and even when they did they would eventually bind up and stop. I took the unit apart several times checking the bearings and that things were in place. Eventually I realized that the weight in the bottom was not seated in place because of silicon that has been pasted all over the bottom, it would move enough to rest against the lower gear box and press enough on the gears to slow and stop them. I cut way only enough of the silcone so that the weight would sit in its clips. Seems to have solved the problem and its going like a race car now.
