Hey all,
See logs below. I had a couple blips where the cc went to 1.5 and 2, is this normal? They were on the 29th and 27th. Also now that I have the TA close, should I block the aeration nozzle now that I do not need to actively raise the PH?
Thanks! *Note: The times may not be exact, I entered the data into the app yesterday things went a little funky, keep the right date but saved as the time I entered even though I entered the time and used the check mark. Went back and changed times from the overview and seemed to be ok.
Mike
Latest Test Result Summary:
FC: 4.0 (23 minutes ago)
CC: 0.5 (23 minutes ago)
pH: 7.2 (23 minutes ago)
TA: 80 (23 minutes ago)
CH: 200 (5 days ago)
CYA: 70 (5 days ago)
SALT: 3000 (3 days ago)
BORATES: 15 (23 hours ago)
TEMPERATURE: 83° (23 minutes ago)
CSI: -0.78 (23 minutes ago)
Test Results 07-02-2018 @ 06:00 AM
Free Chlorine: 4.0
Combined Chlorine: 0.5
pH: 7.2
Total Alkalinity: 80
Temperature: 83°F
CSI: -0.78
Test Results 07-01-2018 @ 06:21 PM
Free Chlorine: 5.0
pH: 7.2
Temperature: 88°F
CSI: -0.73
Test Results 07-01-2018 @ 02:42 PM
Free Chlorine: 5.0
Combined Chlorine: 0.0
CSI: -0.31
Chemical Addition 07-01-2018 @ 11:00 AM
+ 38 FluidOunces of MuriaticAcid31
Test Results 07-01-2018 @ 11:00 AM
Free Chlorine: 5.5
pH: 7.6
Total Alkalinity: 90
Temperature: 86°F
CSI: -0.31
Test Results 07-01-2018 @ 06:30 AM
Free Chlorine: 5.5
pH: 7.6
Borates: 15
Temperature: 86°F
CSI: -0.39
Test Results 06-30-2018 @ 07:30 PM
Free Chlorine: 5.0
CSI: -0.78
Chemical Addition 06-30-2018 @ 03:30 PM
+ 32 FluidOunces of Bleach
Test Results 06-30-2018 @ 03:30 PM
Free Chlorine: 1.5
CSI: -0.78
Test Results 06-30-2018 @ 06:30 AM
Free Chlorine: 5.0
CSI: -0.78
Test Results 06-29-2018 @ 08:45 PM
Free Chlorine: 5.0
Combined Chlorine: 0.3
pH: 7.3
Temperature: 86°F
CSI: -0.66
Test Results 06-29-2018 @ 03:00 PM
Free Chlorine: 6.5
pH: 7.3
Temperature: 86°F
CSI: -0.66
Test Results 06-29-2018 @ 06:30 AM
Free Chlorine: 4.5
Combined Chlorine: 2.0
pH: 7.3
Temperature: 86°F
CSI: -0.66
Test Results 06-28-2018 @ 07:30 PM
Free Chlorine: 7.0
pH: 7.2
Temperature: 88°F
CSI: -0.67
Test Results 06-28-2018 @ 02:30 PM
Free Chlorine: 7.0
Salt: 3000
CSI: -0.78
Test Results 06-28-2018 @ 06:00 AM
Free Chlorine: 6.5
pH: 7.2
Temperature: 82°F
CSI: -0.73
Chemical Addition 06-27-2018 @ 07:00 PM
+ 32 FluidOunces of MuriaticAcid31
Test Results 06-27-2018 @ 07:00 PM
Free Chlorine: 4.5
Combined Chlorine: 1.5
pH: 7.5
CSI: -0.51
+ 20 FluidOunces of MuriaticAcid31
Test Results 06-27-2018 @ 12:17 PM
Free Chlorine: 4.5
pH: 7.2
Total Alkalinity: 100
Temperature: 76°F
CSI: -0.68
Test Results 06-27-2018 @ 07:30 AM
pH: 7.5
CSI: -0.51
Chemical Addition 06-27-2018 @ 07:30 AM
Mike
Free Chlorine: 4.0
pH: 7.2
Temperature: 83°F
CSI: -0.78
Free Chlorine: 5.0
pH: 7.2
Temperature: 88°F
CSI: -0.73
Free Chlorine: 5.0
CSI: -0.31
Free Chlorine: 5.5
pH: 7.6
Temperature: 86°F
CSI: -0.31
Free Chlorine: 5.5
pH: 7.6
Borates: 15
Temperature: 86°F
CSI: -0.39
Free Chlorine: 5.0
CSI: -0.78
Free Chlorine: 1.5
CSI: -0.78
Free Chlorine: 5.0
CSI: -0.78
Free Chlorine: 5.0
pH: 7.3
Temperature: 86°F
CSI: -0.66
Free Chlorine: 6.5
pH: 7.3
Temperature: 86°F
CSI: -0.66
Free Chlorine: 4.5
pH: 7.3
Temperature: 86°F
CSI: -0.66
Free Chlorine: 7.0
pH: 7.2
Temperature: 88°F
CSI: -0.67
Free Chlorine: 7.0
Salt: 3000
CSI: -0.78
Free Chlorine: 6.5
pH: 7.2
Temperature: 82°F
CSI: -0.73
Free Chlorine: 4.5
pH: 7.5
CSI: -0.51
Free Chlorine: 4.5
pH: 7.2
Temperature: 76°F
CSI: -0.68
pH: 7.5
CSI: -0.51
