I don't have any experience with this type of system, but I have done a little work in thermodynamics. I think one way to look at this is that when you need to heat your pool the most, you probably don't have your A/C running. Some areas of the country operate A/C 40+ weeks a year. In those areas a heat recovery system may make sense. I see you are in Erie PA, which is even further north than I am in the Harrisburg area. I use my A/C sporadically in the months of May and September, and the A/C is out of service from October to April, I really only run A/C in June, July and August. Heating my pool would be more of a priority in May & September, when my A/C would not run very often, I don't need to heat the pool in the summer, I have a complete southern exposure, so there are times in the summer my pool is 90+ degrees. Currently today my pool is 85 degrees without the use of any pool cover.
I don't mean to discourage you, but I just wanted to throw that idea out there, just in case you didn't think of that.
I will be curious to see your results if you do install,
