- May 23, 2015
- 24,411
- Plaster
- Pentair Intellichlor IC-60
One has to be careful with painted metal surfaces. Paints are emulsions that contain all sorts of chemicals including the colorants, binders and inhibitors. Back in the old days, leads paints had excellent resistance to chloride and sulfate permeation because the lead compounds would immobilize the chlorides and sulfates as insoluble compounds. Paints nowadays don’t contain lead and so other additives must be used to ensure resistance against water and salt permeation. If the aluminum is coated in a cheap paint, then it would be easier for moisture and salts to permeate it. This will then lead to corrosion of the metal surface between the paint film and the metal casing. Chlorides and sulfates will catalyze aluminum reactions with water to form hydroxides. Once those reactions are initiated, there’s very little you ca do to stop them. So it may be that that corrosion gets started by some galvanic processes but it proceeds due to the moisture in the environment. Sort of like lighting a fuse … once lit, it just keeps going.
