Thank you for the information. It is hard to deal with these re-plastering companies. Some never even respond to requests for them to look at the pool, but the others aren't great when it comes to communicating, either. So far, I've gotten bids from 3 of the 6 I contacted. One company wants 30% more money than the other companies. The one I'm leaning toward is well familiar with the OnBalance program, but has a problem with waiting 6 hours to fill the pool, saying that would cause the upper step to be dry for 30 hours. He recommends starting the fill right away and adding a bottle of Startup Tech. He says Startup Tech skews the results from test kits for 2 days, but it keeps calcium in solution rather than creating scale on the surface of the new plaster. His plaster mix is 6 bags (600#) of marble sand, 4 bags (360#) of cement, 1 bag (50#) of pozzolans, no more than 2% of calcium chloride (less if the temperature is warmer) and 20-22 gallons of water (pH is 7.3, TA is 290 and CH is 330). He also said I should use a brush vac for the first 7 days, not returning my pool cleaner to the pool till after that 7 day period. Here are his start up instructions. Please comment on what was told to me by this company.
Plaster Start-up Instructions
Items Required:
Extension pole, Nylon pool brush, Vacuum brush head (not roller vac), Vacuum hose, 4 way
test kit or test strips, 5 gallon bucket.
Liquids Required:
4 gallons Chlorine & 2 gallons Muriatic Acid, Conditioner, Chelating/sequestering agent.
Note: A clean filter is recommended, as this will give you the best suction and recirculation.
The filter may need to be cleaned again after Start-up, check pressure.
Gallons = Surface area x average depth x 7.5
(Example 15’ x 30’= 450 x 4’ x 7.5 = 13,500 gallons)
The purpose of the Start-up is to remove the Plaster Dust (calcium, calcium hydroxide) from
the surface of the plaster and balance the pool chemistry. The goal is to have the entire pool
surface dust free ASAP. At the same time, you will be adjusting the P.H. against your alkalinity
and hardness readings. Once you have achieve this, chlorine can be entered.
Day 1:
1) Set timer to run pump for 20 hrs. (This will allow dust to settle between days.)
2) Turn on pump.
3) TEST POOL WATER- Hardness, Alkalinity, P.H., (This will determine how much acid to
place in water.)
4) Adding acid to pool, start by placing 1-2 quarts of acid in 5 gal. bucket with 3 gal. of pool
water. Walk and pour solution into pool avoid pouring over steps and benches.
5) Add Chelating/Sequestering agent. (This should be added like the acid above.)
6) Start vacuum, try to go over as much of the surface as possible, steps, coves, walls, floor,
go slow and over lap strokes. (Same for spa.)
7) Re-check P.H. and add accordingly.
8) BRUSH ENTIRE POOL (Be diligent, this also stirs in additional acid.)
Day 2:
Use the above steps of day 1 starting at #3 through #8
(Your trying to achieve a dust free pool ASAP.)
It is critical to adjust P.H. against the Hardness and Alkalinity readings.
Day 3:
(Same as day 2.)
Day 4:
If pool is not DUST FREE, continue with steps #3-#8.
If pool is now DUST FREE, P.H. and Alkalinity are adjusted accordingly. Chlorine can now be
place in pool. (Chlorine can be poured directly into the pool, avoid pouring it in just one area,
walk around pool. Do Not Over Chlorinate, this causes metals to fall out. 1qt. - 1/2 gallon at
one time, brush in, recheck after 4 hrs.)
Brush entire pool.
Reset pump timer to turn over entire gallonage of pool water once a day, 4-8 hrs.
Day 5 - Day 6:
Brush and adjust chemistry.
Day 7:
If Chemicals are in balanced ranges and are stable, liquid or dry conditioner can now be
added.
If dry conditioner, is being used, start with a 5 gal bucket with 3 gallons of hot water. Place
conditioner into bucket, stir in and then pour solution directly into skimmer.
If liquid conditioner is being used, pour directly into skimmer.
This should be done at the beginning of the pump cycle.
DO NOT POUR EITHER IN POOL.
Floating chlorinators and or tab feeders can now be used.
Floating style chlorinators should be tethered and not allowed to float over steps, benches, and
should not have access to skimmer throat.
Automatic pool cleaners can now be used.
