I have an A&A 6 port low profile control valve, I believe I have a problem with 1 of the ports being clogged. I want to remove all the poppers and open all the ports on the valve and use pool pump on high to clean out the plumbing. Is this possible?
Is the issue on one zone or multiple zones?
Is all return flow being sent to the IFCS?
Does the water distribution valve have T-valves or acrylic balls below the gearset?
If you were to open all T-valves or remove all acrylic balls at the same time, the water flow to each zone will be reduced as all 6 ports will be open.
You can remove popups one at a time on each zone and allow the system to cycle thru each zone. Be sure to lube the popup O-rings with pool lube before reinstalling the popup. With the pump on its highest speed, smaller debris will exit the removed popup pipe.
Tell us more about your pool by filling out your signature with pool, all pool equipment (including manufacturers and model numbers) and test kit info.
