Thread: Muriatic Acic question
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    When lowering your pH by using Muriatic Acid (31.45%) and using the Pool Calculator to establish amounts how long will it take for the pH to stabilize assuming the filter is left on for circulation?
    My TA is 100.
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Muriatic Acic question
    If the circulation in the pool is good, then the water will be reasonably well mixed in about a half hour, but you can test after an hour to be safe. If you wait too long, then the pH may start to rise from outgassing of carbon dioxide from the pool. Remember that The Pool Calculator is only approximate when it comes to pH calculations, but it's a good start.
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Thank you CG
    Polaris 280 robot
    Pool Calc user
