I have a splapool sand filter (I think). it doesn't have any information on it regarding model # or size that I can see. I measured it around and its 52in completely around. I have a 24x 52 above ground with 1hp 2sp pump. Is this big enough?
The filter is a little small but I suspect you are asking this question because the pool is not looking right? Perhaps cloudy? More than likely you have a chemistry problem and not a filter problem.
