Pool: 600 square feet gunnite pool with attached spa
In order to drain my pool to prepare for painting/resurfacing, I needed to seal the spa pipes. Since I didn't have the proper plugs, I found 2 round rubber balls (slightly different sizes) to seal the 2 spa pipes.
It worked great. Pool is now empty as I research masonry finishes.
When draining was complete, I went to retrieve balls but 1 was missing. It must have been sucked into line at the very end. Do I run the garden hose in the pipe where I inserted the ball, however, I fear pushing it farther? I'm not sure where this pipe leads (either to pool return or back to pumping station. Likely not Skimmer since it is on opposite side of pool.)
Other posts mentioned Drain King. Is this available at Home Depot/Lowes?
Information appreciated!!
