Adding a gallon or two of bleach here and there is hopefully enough of a placeholder to keep things in check until you have a clear plan to SLAM it.
as I read this I wonder if you damaged your spider gasket.
not filtering,
not backflushing,
in recirculation mode sounds like it is leaking or severely damaged.
Here is a how to on pics
http://www.troublefreepool.com/faq.php?faq=vb3_board_usage#faq_posting_photos
the reason I said your spider gasket might be bad. 9-10 filter on, that is OK. but when in recirculate mode it should be re-directedThe difference in the above pictures is actually 12 bags of 1lb shock and two 1liter bottles of black algae killer (w/second 6 bags) 1bottle algicide (w/first 6 bags)
A new cheap gauge was screwed on. It goes to 9-10 on filter, zero on off and back to 9 on recirculate.
Added 1gal bleach, 4lbs stabilizer and 16lbs baking soda last night. Will test later today. Hoping to shop for unions.
I had hoped you might have gotten back to reading your original forum postings rather thanAfter 4lbs stabilizer and 16lb baking soda:
TA 100 (made water clear, not red, not green)
pH 7.3
Chlorine almost 1
CYA less than 20
Now what? remember pump not working properly. Hoping for big boost of self confidence tomorrow to saw some pipes. If all goes wrong, I could be without circulation all together.
I just added one gallon of bleach. Not really understanding SLAM yet with not being able to vacuum and FC and CC and all the testing and math.
A few comments that I will leave in this thread so as to not confuse the wovens. If eaamon would like to discuss any of this, then please do so in your own thread that I created with the rest of your posts.crystals, well it eats up your chlorine fast. this is the why I recommended you put it in just
one pound at a time. it takes CYA a week or more to totally dissolve.
during that time it will change your PH and TA some times fast. I might have recommended going to your local pool
shop or wallys world has them AQUACHEK Yellow Swimming Pool Spa Chlorine 4 in 1 Test Strips Aquacheck 50pk - Walmart.com
use these to check your water several times a day to be sure there is some kind of chlorine,
PH is close and TA holds. adding the acid you did might change things in a hurry. you need to stay on top of it.
now that your pool has been back flushed and a reading of 10 PSi you should not have to back flush again until
your pressure goes above 20 PSI....do it at 21 PSI in other words.
I said panic mode. let me explain the more CYA you add the MORE CHLORINE YOU NEED TO SHOCK YOUR POOL.
OH! that is the why when you missed my post in the other forum...cautioned you of this. the reason why I said just one pound.
CYA amount large number costs a lot for enough chlorine to shock a pool.
a very low amount or no CYA just a few bottles of chlorine is enough. my pool at my just bought house a year
earlier had a CYA of about 300 or there abouts. chlorine cost me abundle, nearing $300 plus as CYA kept
eating the FC up as fast as I could put it in.
We've all been through what you're going through at some point. It's very frustrating, but calm down and stick with it. I can't tell you how many times I've fixed something just to have something else fail.Good grief! Every time I fix something it leads to something else!
I tried to fix small leak where pipe meets pump. We replaced the cleaning line lever hoping to get more suction now being able to turn that off.
Now I have LESS suction all around, barely enough to circulate! Water is also leaking from underneath pool pump. Lots of tiny air bubbles, not sure where it's sucking that from.
Help! I'm thinking in the end $2000 to have pool people get all this going might be my only choice. I am so frustrated. Why won't this thing work? It keeps getting worse than better!
I would post pics but it says exceeded quota and I can't find where to manage photos (my 1.5 year old computer crashed too so I'm doing this on a 4 yr old phone.) see why I can't be bothered with pool issues?! Ugh!
Seeing tiny bubbles in the pump basket is why you have less suction. You may have disturbed an old o-ring when you tried to fix the leak and that's where the air leak is.
Remember, this is not an emergency. If you have to take a day off from it to calm down a little, it's not the end of the world.
Once you've calmed down a little just go back out there and start looking for where the air is leaking into the pump. Having to redo PVC a couple of times is no big deal.
People have written a lot of stuff above, but don't let that overwhelm you. Lets tackle one problem at a time and we'll work through your issues before long and you'll be having a truly trouble free pool.
Post back once you're ready to start and we'll help you through it.
