Should I lower my CYA down to lets say 70 from 100 where it currently is ?? Could I just set the SWG at a higher % because of the CYA level of 100 ??
Remember, 100 is the limit of the CYA test. Have you done a diluted test to verify that is is 100?
You did a diluted test and came up with 55? The CYA test doesn't go up to 110.
*******On Edit
I was on my iPhone, so it was hard to type. If the CYA test is at 100 or above you need to do a second diluted test. If it's just a "little" above 100 on the test you can't equate that to any number.
Yea, when it gets around 100 you start wondering.....Yes exactly, it seemed to be slightly over 100. I had to ask myself "is it 100 or over 100" several times. OK, off to take another test !!
*****UPDATE: 50 on the diluted test.
not a problem! We wouldn't be here if we didn't want to help.Thanks for the help Tim. I'm going to drain some water and get the CYA down a little. I do prefer the levels be balanced as per recommendations here. Thx again!
