So I added the second ground.
So I fired it up (9th time cold fire in a row).
Still get .8vdc from FC when it is fired.
....and voila....it ignited when it called for more heat. So I'm all happy. I get the wife and some beers and have a nice soak in the spillover spa to celebrate. The heater came on 5 times during the soak. Worked perfectly!!!
So this morning, I decide that I'm going to "prove" that it was a grounding issue. My plan is to:
1. Fire up heater and after it reaches temperature, raise the temperature to cause the heater to fire up again.
2. Remove the second ground
3. Raise the temperature and witness the failure
4. Attach the second ground
5. Raise the temperature and witness success.
This is what happened:
1. Fired up the heater.
2. When it reached temperature and shut off I raised the temperature to cause the heater to fire up again.
Heater did not fire....it failed!!! So I'm thinking, "Forget my stupid test".
I wait a while and fire up the heater (11th cold fire in a row).
The heater reached temperature and shuts off.
I was working on something else. When I checked the heater the "service heater" light was on. This tells me re-ignition failed.
So its been a while, I attempt a 12th consecutive "cold fire"....and guess what? Heater won't fire.
So I shut off the power to the heater for 10 seconds.
I attempt another "cold fire".....heater won't fire.
Three flashes on the ignition control module which indicates "ignition lock".
I checked the ohms across the igniter....read 52 ohms.
So I think we are getting "unpredictable results".
That's the phrase we used when I worked at IBM in the 80s when we had no idea what was going on.
So I guess the next stop is the ignition control module.
This is my last attempt before trying to find a competent tech.
My reasoning is as follows:
Cost of ignition control module on Amazon: $130
Cost of tech if it is the ignition control module:
$90 to come out
$100 labor
$230 for ignition control module (or some cost significantly more than Amazon)
So I figure that I'll gamble the $130 to avoid the $400
Couple of days to ship....I'll let you know how this turns out.
Any suggestions for a heater tech in the Harrisburg, York, Lancaster, Mechanicsburg area of south-central PA?
Question: What is the FC on the ignition control module? What does the fact that I get only .8vdc instead of 3.0vdc mean?
Thanks for your help.
