900Mhz Pentair bridge issues or troubleshooting
Feb 26, 2015
15
DeLand, FL
Hey..
New to pentair systems (coming from omnilogic at my last pool), have the full intellicenter panel and apparently the 900mhz long range bridge that plugs into my network.
I had this unit running what I felt was running well for the first two months and all of a sudden I couldn't connect to the pool via the app... Turns out as I started troubleshooting, I could ping the intellicenter on the LAN but had extreme packet loss and latency.
What was odd, from day 1 it seemed flakey (app connectivity) and now I realize it was just some issue which appears as packet loss. Rebooting sometimes recovered but the other day no power cycle or reboot was restoring it.
I know the cables were all good (tested) but ultimately decided to move the network side directly to my core network switch to eliminate a network run. Plugged directly in and it came back to life.. but then started doing it again, significant packet loss and latency (like 3500ms) and ping loss of like 80%
I've rebooted it a few more times and it started working... mostly. It can run for hours without packet loss and once in a while it seems go bonkers again
Anyone see anything similar with these units?
Sounds like you have some other 900MHZ device that is causing interference with the wireless bridge.
Try a different wireless bridge, like from TP-Link.
