Results 1 to 9 of 9
Thread: Will a pool cover help keep the pool clean?
    Hiya,
    I live in South Florida and have a pool that isn't screened. I also have several Live Oak and Pine trees. I spend a lot of time skimming and cleaning the pool. Most of my problem is with floating leaves. On a windy day more leaves can fall while I'm at work than the skimmer can handle. A lot more. So I end up with the skimmer clogged and a billion leaves to skim.
    I don't have a lot of problem with the pool getting too warm. Today it's at 82, which is as hot as I've measured it in 10 years. Typically it stays below 80. For about 6 or 8 months of the year, I wouldn't mind raising the temp a few degrees.
    I'm toying with the idea of putting on a floating solar cover - more to catch debris than anything else. But I'm not sure how effective that will be. I'd be leaving it on 24/7 except in the depths of summer (like now).
    But I'm trying to figure out how having a billion leaves on a floating cover is going to be any easier to deal with than a billion leaves in the pool....
    Thoughts?
    17,000 gal, sand filter, 3/4HP
    Jun 2007
    Arkansas
    88
    Im far from expert, but I think a floating cover with leaves will be just as bad or worse than leaves in the pool...
    Andy
    15' X 4' Round AG
    BBB method and loving it!
    Ohio
    217
    Hi saltyzoo
    I live in a area with lots of trees. I do use a solar cover and it will hold the leaves and junk that blows into the pool. sometimes if there is to meny I use a broom and dust pan to clean up the cover before I crank it off. sometimes they just blow off. I always have some go into the pool that I have to use the net on. a good cover for the pool floats very solid and there is no problem sweeping them. There should be no problem getting 5 to 10 deg gain in Florida with the solar cover. I would say yes go for it.
    Ric W
    My Pool
    8605 gal fiberglass, 3/4 hp pump, sand filter, aquabot cleaner, heat siphon heat pump, tiger river(sumatran) spa
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    I agree. I live in an area with lots of trees/leaves and it is also much cooler here than there. The things that the cover will do for you is:
    1) help keep the leaves out of the pool (cover is much easier to clean off than leaves IN the pool) We sweep, rake or roll the leaves off as we crank up the cover onto the reel. If you have HUGE amounts during autumn, a leaf net over the cover may be the way to go
    2) Keep the heat you have from escaping at night and when there is wind or the temps drop below your target water temp. This is by far one of the biggest advantages of keeping your pool covered. You can heat your pool anyway you want or let Mother Nature do it for you but you will have to keep on working at bringing that temp back up so much more if you do not RETAIN the heat.
    3) Minimally add some warmth - they really do not increase the temps so much that you can count it as "heating" but the surface 2-5" may heat up 5 deg or more.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Ft Lauderdale, Florida
    1,462
    Hey Saltyzoo,
    I'm in Coral Springs with an uncovered, unscreened pool with loads of my neighbors pine needles ending up in my pool. A good cleaner (I have a Sta-Rite Great White) and in line leaf trap (Hayward # 180) will do wonders to keep your pool clean. I don't deal with too many floating leaves and my skimmer is where I plug my cleaner into so very little problem there.
    The Great White has a large throat to suck up large items.
    The in line trap has a clear body so I can see when it needs to be cleaned.
    The cover will work and make sure it is larger than your pool (you can cut it to size) so that the ends are right to the wall, allowing very little debris to end up in the pool. Also, make sure you're lifting the cover periodically to check for debris that may have gotten past the cover.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    I used to use a solar cover but hated all the junk that fell into the pool when I removed the cover. This was usually right when I wanted to swim.
    ~Megan
    To add to NWMNMom's list:
    4) keeps water loss due to evaporation down
    5) (not 100% on this one) Helps keep the chlorine in by blocking the sun a bit
    You will probably have to take extra care when removing the cover so the leaves don't end up in the pool, but if you go slow and maybe tuck up the edges as you go, I would think you would be ahead of the game (as opposed to much scooping and vac'ing)
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Quote Originally Posted by The Mermaid Queen
    Queen's right on her points - but i've never been terribly impressed with my solar cover's ability to keep debri out of the pool. If the cover is cut to fit the pool perfectly, it's hard to remove but keeps more stuff out. If you cut it slightly smaller, there's debri that gets in the water, and if it rains with debri on the cover - wow what a mess!
    My other main concern for you is that in south Florida, a solar cover may just lead to one very large hot tub. Your water temps may climb to the point of a) being uncomfortable and/or b) being so warm or hot that your chemical usage will go through the roof.
    6500 gal. Fiberglass HydroPool w/SWG = 9' x 18' x 6';
    Apr 2009
    Central Minnesota
    74
    Re: Will a pool cover help keep the pool clean?
    I use a safety cover for three reasons:
    1) To keep small animals (gophers, muskrats, rabbits, etc.) from drowning in the pool.
    2) To keep out the pine needles and leaves from falling in the pool.
    3) An exra layer of safety for toddlers/children.
    All the needles and leaves simply blow off. The few that stay behind on the cover I just hit with a water hose or leaf blower. Would never go back to a bubble solar cover again.
    18' X 36' X 4.5' vinyl oval in-ground 17K gallons, 250K BTU Pentair Master Temp NG heater, 1HP Hayward Super Pump, Hayward S200 sand filter, Hayward Pool Vac, Extreme mesh safety cover, TF-100 test kit.
