So back to my pool's currently high CYA. Is draining half of my mammoth of a pool the best solution?
Yes. What is the rate in your locale for new water? Nationally, it seems to average around 5-7/1k gallons.Is draining half of my mammoth of a pool the best solution?
I agree. The only time RO would make sense in my mind would be when there are water restrictions in place. Unfortunately, RO does not seem to be an option in locations that actually have regular water restrictionsThis thread has wandered around a bit but it points out how we probably emphasize R/O too much.
When you consider it is very limited in availability and the price is NEVER as cheap as drain and replace, I don't think it is much of a solution.
For every 10 ppm Free Chlorine (FC) added by Trichlor, it also increases Cyanuric Acid (CYA) by 6 ppm. No mystery here. If you have 2 ppm FC per day chlorine usage, then using only Trichlor would increase the CYA by 36 ppm per month.
