Thread: TF 100 kit, labels moved. What is +/- on sensitivity?
    Jun 2008
    Buffalo/Niagara Falls NY
    30
    My label on my CYA mixing bottle slipped slideways. How much do you need for testing. I would like to mark it with a permanent marker for proper levels. Remember, I am a "lab rat" so I worry about precision and accuracy.
    T.
    15x 30 inground oval vinyl lined. 15000gals. Jacuzzi 250lb sand filter. Laars lite natural gas heater. 6 foot slide, underwater light . 3.5 ft. shallow,to 7ft. deepend. TF 100 test kit
    Guest
    Re: TF 100 kit, labels moved. What is +/- on sensitivity?
    equal parts pool water and reagent. For the large view tube it's usually 15 ml and 15 ml but if you know your CYA is high you can use less. say 10 ml and 10 ml.
    Jun 2008
    30
    I kind of thought it was an equal parts test.
    Thanks again!
    TFP is the best!
    Teresa
