I've been having trouble with my Intermatic timer recently. I have the regular pump set to run between 2 and 7 each day and the booster pump from 2 to 6. The timer for the pump is regularly getting stuck at the 6:00 position. As an example, this morning I discovered the pump was on and when I checked the pump timer it is stuck right around 6:00.
When I look in the view hole for both timers I can see them both moving. I have an Intermatic PF 1222TB as pictured below. Can anyone help me diagnose this problem?
