My pump has never given me a problem until now. It was working fine today until I turned my Easytouch to spa mode to run the heater for an hour or so as I occasionally do.
The valves turned to go into spa mode but the Whisperflo turned off during the switch to spa mode and I can't get it to turn back on. The Easytouch indicates that the pump is on, but nothing happens. No clicks, humming or anything. I've turned my breakers (both at the breaker box and within the Easytouch unit) on and off several times and I've checked the wiring and everything looks fine. I noticed that my SWG also appears to be dead which I believe tells me that no power is getting to the circuit (the SWG and the pump are on the same power relay (right word?).
I'm not sure how to tell if the pump is getting power, but I suspect it is not. Any ideas?
