Thread: Winter Cover sizing
    Winter Cover sizing
    I have a 24' round AG pool and last winter we had a 24' winter cover on it. Even though I tied milkjugs to it, the wind would billow under it and over the winter it rubbed the finish off some of the aluminum top plates.
    The cover barely went over the edge of the top plates in most locations. I was thinking about using a 28' round cover this year and using the jugs/clips/wires to hold it down. This way, with the edges of the winter cover over the top plate and down the side of the pool, it might resist the wind getting up the corners of the cover.
    Does anyone else use larger winter covers than the size of their pool?
    Larry,
    20,700 gal gunite/plaster ig pool w/ SWCG and DE filter near DFW TX
    Montreal Canada
    326
    Re: Winter Cover sizing
    Mine's an 18' and I think my winter cover is a 21' (came with the house). I keep it down with clamps from the dollar store:[attachment=0:y562bdgq]pool.jpg[/attachment:y562bdgq]
    My error was clamping down the cover when it was too taut, the weight of the snow caused it to tear at some places. This time I'll leave it so it just touches the water (the pool is drained 2/3).
    May 2008
    Fort Gratiot MI
    66
    CaOCL2
    What do you mean you clamped it down with clamps from the dollar store, what kind of clamps? Also did you have to use alot of them and did you attach them to the top rail?
    I ask as this is my first year of closing a pool in a very long time and I dont rmemeber anything at all about the closing of it.
    Thanks
    Brian
    24' round Vinyl liner Doughboy 48" deep 52" sidewall
    1hp Doughboy pump w/timer
    Doughboy Silica II filter with Zeosand
    Raypak 180,00 btu heater
    BBB method
    Sundance Optima '97 450 gal. spa w/Delzone ozonator
    Beats driving to the lake, and I'm only a block away from the lake!!
    Montreal Canada
    326
    I didn't take out the winter cover just yet so I used a dish towel in its place just to show what I mean:[attachment=0:190s5lmn]DSCF6203.JPG[/attachment:190s5lmn]
    Because of the way the pool is constructed I'm able to attach the clamps to the 2x4s along the pool. There's nothing holding the cover to the top rail but that may certainly be an option. Actually I may just do that this year.
    diloglm's Avatar
    Jun 2008
    Bel Air, MD
    8
    Here`s another suggestion, last winter I used bungee cords which went through the grommets of the liner and then attached them to stakes in the ground. Prior to that I had used the milk jugs and had the same problem with chafing and rubbing off of the paint. It was also a time consuming task! I live in northern MD and had no issues with the big, hard plastic stakes coming out of the ground. I found this method easy and it allowed a little give as well.
    Lisa
    My Pool: 24` round AG with surrounding deck, 13,500 gallons
    1 HP Hayward Pump, Sand Filter, BBB user and promoter :)
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    You can buy what's called a "skirted" cover which comes about halfway down the pool wall. Here's a link that shows what it looks like.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
