Algae spots?
May 30, 2014
52
Saint Albans, WV
I've noticed a couple spots on my liner on the bottom of my pool that are turning green :/. My chlorine is between 5-10, ph - 7.5 and my CYA is 50. Any advice. Im close to closing the pool up and don't want this to create a bigger problem next year. Any advice appreciated. Thanks!!!
PS - i've just been putting in diver dave to cure the problem but they keep coming back.
Any visible algae you need to follow the SLAM Process. Follow it to the T and it should go quickly.
The reason for it could be poor circulation in that spot or your FC level dipped below your min for your CYA level which is 4. You got the right test kit so SLAM it ?
