I just want to say that dead algae on the bottom does not equal to crystal clear. Are you keeping a log of your test results and how much bleach you are adding? This will give an idea if you are either: a) overestimate the size of your pool, b) underestimating the strength of your bleach, or c) error in your use of pool math.
What is your CYA? How often are you testing FC?
Please add your pool details to your signature... many of us read many posts and having your info in your signature makes it easier, faster and you'll get better advice.
Signature
Please put the following information in your signature.
The size of your pool in gallons
If your pool is an AG (above ground) or IG (in ground)
If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
The type of filter you have (sand, DE, cartridge) and, if you know, the brand and model of the filter.
If you know, please tell us the brand and model of the pump, and mention if is it a two speed or variable speed pump.
Date of pool build/install, particularly important if less then a year old.
What kind/model of water test kit you are using
Other significant accessories or options, such as a spa , SWG, or cleaner.
