I installed a 240V intermatic timer and I have a 120V feed to the timer because the pump is 120V. I have wire the terminals to run the pump at 120V, but the timer box only works as a switch currently, I want to have the timer working, but... The timer switch needs to have 2 lines connected to spin the timer dial because I think it is a 240V switch unit. Can I split the 120V wire and energize the timer or will this cause the timer to get destroyed? Does anyone have any suggestions to make the timer function work?
