Okay, finally got around to testing the pool again (8/25). Hopefully I'll have time to do it again tomorrow.
Anyway, today's test results:
FC: Still orange I assume this is well above target
Technically TC. You can temporarily stop using the OTO test due to the current condition of your pool.
pH: 7.8 Top of the acceptable range, correct?
Yes, but would need to be lowered for SLAM.
FC: 16.5
CC: 1.5
See comments below.
TC: 18 In range?
It is the FC/CC readings that matter, not the TC.
CH: 275 Bordering on the low side?
Within defined limits.
TA: 120 Way too high, correct?
Don't worry about it at the moment.
CYA: 50 Too low, correct?
No, because you need to SLAM.
Couple of reminders: A couple of weeks ago our original SWG that lasted ~7 years malfunctioned, so it was replaced the SWG. The water is getting much clearer, but there is still some algae present.
Any immediate suggestions?
SLAM the pool.
And thanks all
