Thread: Crypto update on ABC today
    Guest
    http://abclocal.go.com/wjrt/story?secti ... id=6298303
    this was on GMA today. Hadn't heard about the NY incident before.
    I realize that it's probably not an issue for home pools, but friends may not realize that and may be asking questions.
    Dec 2007
    Central New York
    504
    Re: Crypto update on ABC today
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Guest
    Yes, those links have good info.
    Here's another post from this site re: a Wall Street Journal article on crypto today. Nothing we haven't heard before, but it's in the news again.
    chlorine-reistant-parasite-t8636.html
    Jul 2008
    144
    One of the things you can do to help prevent or clean up such problems is to temporarily use bromine. Bromine does not combine with Cyanuric Acid and is, therefore, much more effective. Boost the bromine levels to the recommended levels to kill the pathogens. Since many of my customers have automatic covers, I can switch over to bromine without much concern for rapid loss of sanitizer due to UV light. For outdoor pools without a cover you will use more chlorine as you switch back to chlorine due to the fact that the pool will remain bromine for a while.
    Jul 2008
    Bucyrus, Ohio
    108
    Apprx a month ago they went thru and cleaned the Columbus Ohio city pools because this crypto was found to be in the water there as well. Many children I am thinking they said somewhere around 30 at 1 pool became ill. Sure glad I dont have strange children in and out of my pool everyday.
    Overwhelmed
    Pool size: 15' X 48" AG vinyl liner, 5300 gallons, Hayward S166T filter and 1hp pump
