Hey Everybody --
Hope your pools are doing great for you ... Temps in the high 80's here and humidity off the chart.
Got a question or two.
Using a Taylor K-2006 Test Kit.
Yesterday's readings:
FC .5
CC .5
Ph 7.0
TA 50
CYA <30 Added stabilizer at the recommended rate using the BleachCalc on this site and was going to add the proper amount of 6% bleach tonight and adjust the TA too.
Here are todays readings:
FC 1.5
CC .5
Ph 7.0
TA 50
CYA 30 but slightly dingy on the black dot at bottom of tube
Question 1: Why a variation in the FC today from yesterday with only the addition of CYA yesterday.
Question 2: Added the calculator's recommended amount of CYA (6 lbs) and made only a slight change in the
water clarity in the test tube. Went from a very clear way <30 to slightly dingy 30 today.
I'm not a chemist - so go easy on me. Hahaha
FC .5
CC .5
Ph 7.0
TA 50
FC 1.5
CC .5
Ph 7.0
TA 50
