Assuming you either don't have a DE filter, or do have a DE filter and are remembering to use the rinse setting on the multi-port valve: That almost always means a problem with your filter, torn cartridge, torn grids, or channelized sand, depending on the kind of filter. This can also happen with a defective multi-port valve, though then the symptoms are usually a little different.
