Pictures
I think new folks have a size limit on pictures. Here is a tutorial if you want to use flickr:
http://www.troublefreepool.com/thre...tures-to-a-post-(full-guide-with-screenshots)
Or you can support this forum and post more photos:
http://www.troublefreepool.com/threads/144-CLICK-HERE-to-Become-a-TroubleFreePool-com-Supporter!
For your signature:
Click on "Settings" at the upper right of your screen. Scroll down to the lower left and select "Edit Signature". Here are signature details we like:
The size of your pool in gallons
If your pool is an AG (above ground) or IG (in ground)
If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
The type of filter you have (sand, DE, cartridge) and, if you know, the brand and model of the filter.
If you know, please tell us the brand and model of the pump, and mention if is it a two speed or variable speed pump.
Date of pool build/install, particularly important if less then a year old.
What kind/model of water test kit you are using
Other significant accessories or options, such as a spa , SWG, or cleane
I did that but it's not showing up on every post I make.
If you added CYA a week ago it should register on the test now. Are the test results you posted yesterday current?
It was only a couple of days ago. No they are not current anymore. About to go run another test.
